Wow Rod, your bike looks even better than I imagined with the 24MTB front and the 17MC rear.
Yes I was supprised too. The smaller wheels havent distracted from the look but made it better
That tire combo on your Phasor looks better than the same set up on my Bomber.
It still looks good though Rick,
SWEET!!! Pedal/ground clearance looks to be good as well.
I started with 400mms clearance so there was always going to be plenty of clearance.
That was a concern I had but apparently not an issue. That is one tough set up now. I will bet if you look at the difference in weight with this set up VS the old 26MTB set up, probably not much more than 3 pounds heavier and way way way stronger than before. So, did you notice a slight increase in acceleration capabilities due to the mechanical advantage of the rear wheel?
Yes theres quite alot more acceleration considering that the controllers only putting out 30 amps and the crystalyes one that I had in was 45, hope to try the crystalyte controller on the weekend. Does anyone in Perth have a laptop that can reprogram my Lyens controller. If you do will you reprogram my controller
Your bike will handle better down hill now and straight line stability is also in enhanced, but how is the steering?
Stearings good no issues but Ryans bike with the 180mm for was too twitchy for me.
It should feel slightly less twitchy at speed and should feel a little slower handling wise around or less than 15KPH. If it does feel too slow for your taste (I don't think it will though), decrease your rider static sag by turning the spanner nut on the shock clockwise a couple of revolutions around the shock. BTW, if you are running the tube I sent you in that front wheel, that is a Motorcycle tube 80/100-21. This size tubes work better in big 24x3.00" MTB tires than the 24"MTB tubes. 24X3.00 MTB tubes are hard to come by and are more expensive. A regular motorcycle tube is the same as a heavy duty bicycle tube. If you were to go to a heavy duty motorcycle tube on the front, it would add another easy .5kg to the weight of the front wheel because those tubes are heavy.
Yes im running the tube that you sent me. Ill have to remember this, 80-100-21. Will try and have a good ride tonight as it was dark last night when I finished fitting the wheel.
Rick
