Rix
100 TW
Oh Lifepo4, I was thinking you meant Lipos. You are correct and it will be fine.Sr.Agaporni said:24s lifepo4 would be a max of 87 volts, but thanks for the info.
Jimboyr6 said:Nice work
I the vid showing sprocket play,
Look to me like just movement in the sprocket,mine was abit like that, take the allen key out put washer behind it job done.
Stealth_Rider said:Jimboyr6 said:Nice work
Jimboyr6 said:Not really!,been there seen it fixed it with a washer no drama,
Mines perfect done 2000miles
Allex said:Thx for the picture, I never seen DC1 that close and what it can show!
Stealth_Rider said:Jimboyr6 said:Not really!,been there seen it fixed it with a washer no drama,
What washer did you find that fits?
Jimboyr6 said:Rather than me make a shim, Stealth tech support is working with Suntour for availability as Stealth tells me that have seen this problem before but didn't know its cause.
Jim
Jimboyr6 said:So iv managed to get some of these denzel tyres 24x3 he did come on here showing us these some time ago.
I shall fit soon and report back
One thing iv noticed is the carcass is very strong,sidewalls nice and strong so should have good puncture resistance
bigbore said:Jimboyr6 said:So iv managed to get some of these denzel tyres 24x3 he did come on here showing us these some time ago.
That thread pattern is exactly the same as Maxxis Holy Rollers.
Samd said:I'll wager it's still gonna hoop under torsion on a heavy bike.
Jimboyr6 said:thay dont run true
Jimboyr6 said:Mmm not quite true thay dont buckle under hub motor weight,u can run low pressures,
Its a visual wobble cant feel it when riding
I shall do more testing on way home, report back
stritzky said:Jimboyr6 said:Mmm not quite true thay dont buckle under hub motor weight,u can run low pressures,
How did you order these Tires ?
I Ordered 4 Tires from Denzel And I have never heard anything from them again.
bigbore said:Cromotor and Stealth Bomber![]()
Anybody have already installed a cromotor on a Bomber?
Which winding would be equivalent to the stock 5403 motor?
5403 motor data:
http://www.crystalyte.com/5403%20series.htm
I would say the 30*4T with a Kv=11.5:
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65972&start=275#p1087204
Allex said:Cromotor 4t will beat the shit out of 5403 I was doing drag race against another max-e bike with cromotor. It just vanished in front of my eyes, both had same settings, 110DC amps
And yeah, it had the same top speed. We both hit 110km/h during that race.
Just like Rick said Hyena had one in the works.
