Kionic
- Joined
- Oct 1, 2019
- Messages
- 11
Hi Guys,
I want to discuss some technical matter with you all regarding Pedaling a electric Bicycle without battery power.
Since I have build a few Electric Bicycle, I've observed Geared Hub motor e-Cycles are very easy to pedal without power but where's there's a Gearless Hub Motor It drags very much. In my 1500w Motor Bicycle only can be pedaled on bigger gear & that also very difficult.
I've removed the Gearless Motor connection & then tired Pedaling as I thought it's working like a Dynamo & drags to generate some energy but even after opening the Connection also the Drag remains Same.
It's not because of the weight I believe as I can easily Pedal the Bicycle with 55kg sister when it was not electrified.
On Geared Motor there's a Clutch kind of mechanism. when on Pedal it frees the Motor winding, So its' easy to pedal.
Pedaling is an very important thing as it's a BiCYLE 1st then Elctric. If no Pedaling possible then why Bicycle, will go for Electric MotorBike or Scooty.
Pedaling gives a good mental & Physical health & gives positive energy, reduce stress. In worst case there's some failure in the system you have pedal it to home or garage. Please help me Pedaling a Gearless Hub motor.
