Alan B
Thanks for the report. Interesting. It does not sound like the turn-off circuit is working quite right.
These boxes are available in a few different depths. I don't know which one is pictured, but maybe the wires would have enough room in the next deeper box but still fit the board the same way.Alan B said:Could always put the same board in a larger box. Lots of possibilities for repackaging.
Alan B said:What values did you use for all the parts? Just to understand the test correctly and record it here.
R1,R2 1M nominal 1/2w
R3 1K
R4+7 1K
C1-3 1uF (NonPolar) 100v - one C installed on the upper side of the board @C1
D1 12V zener
D2,3 1N4148
Q1-4 Main FETs, nominally for 90V: IRFP4110PBF - installed @Q1&Q4
Q5 2N3906
do you mean the relation between R1 and R2 should be lower? or that both' value should be lower, so both are 100k? just to be sureAlan B said:R1/R2 should be lower, try 100K. This should be tried before we give up on the PNP.
