I have completed the 2nd beta version (v1.1) of the master switch board. As I am in the US it was no problem to get parts from Mouser. My bike has an 18S battery and I choose a 1 uF MLCC leaded, 100V TDK capacitor rather than using SMT caps. As the board has few parts, is can be assembled in a short amount of time. I did run into problems soldering the power FETs and the 12 awg leads to the board. My wimpy 20w fine tip soldering iron simply wasn't up to the job, which should have been obvious to me from the start. The big copper traces did just what Alan designed, they rapidly dissipate heat. So either no solder joint or a really ugly, cold solder joint was obtained. To save myself from great humiliation, I won't reveal how long I persisted with the undersize soldering iron before I realized the error of my ways. In any case, I bought a Hakko FX-601 by mail order which did take some time. But it seems like a quality tool with adjustable temp (464 - 1000 F), interchangeable tips, etc. And I am happy to report it makes soldering the big leads to large copper pads relatively easy.
In initial tests the board seems to function as expected. When connected to the battery minus and with output controlled through J1 by a switch and measured by connecting a voltmeter across the controller minus output lead and battery plus lead, there is an initial voltage upon connection to that battery that declines towards something like 1V. Closing the switch at J1 then increases the voltage to the battery voltage, in this case 70.2V in something like 1-2 sec. Opening the switch decreases the voltage, falling to about 1V over something like 20-30 sec.
The time course of voltage changes are much different after connecting the switch to a controller. The controller is a 12 FET from Ebikes Canada which has it's own on/off switch. For the test of the master switch, the controller switch was turned on. With the controller connected to the master switch, it seemed like the on time was similar, probably something like 1-2 sec to reach full voltage of 70.2V. When turning off the master switch, at least as measured by the time for the Cycle Analyst to shut off it's screen, it seemed like voltage fall was almost instantaneous. However, upon shut down there was then a surprising, regular, periodic flashing of the CA screen. This flashing of screen can be eliminated by turning off the controller switch.
When I figure out how to hold down the completed master switch board for a photograph, I will post some pictures.
Rich
