Hello all.
I'm posting here in the hope of getting some help from this very knowledgeable community & also to hopefully get some kind of response from EM3ev regarding my issues - here's my story:
I'm building a solar assisted touring trike & after searching around the webz for a few weeks I decided that the EM3ev 52V (14S7P) Hard Case Rectangular battery was the best (albeit pricey) option. I had several email conversations with Joseph regarding my project including the solar aspect & the ability to change the battery on the go from the solar via the Anderson recharge connectors as shown on their website. Joseph was very knowledgeable & helpful which was a deciding factor for me so I went ahead & ordered one with the dual speed charger for good measure.
After 3 weeks with apparently no tracking change I emailed EM3ev requesting some info on it's whereabouts & they said they would contact the courier & find out. According to a web search, there are at least 2 international airports within a 100km range of the EM3ev address, so it was difficult to imagine why a courier couldn't transfer the parcel to one of them within 3 weeks, so I looked up the courier (DTDC) on TrustPilot out of curiosity & my heart sank - they had the worst reputation I had ever seen for a courier - 1 star, just.
I hadn't heard back from EM3ev so, armed with what I had learned about the courier, I contacted them again via email suggesting that they should consider the parcel missing/lost & we should organise a replacement asap as it was almost a month since the order was shipped. Thankfully, the very next day it turned up in the UK & was delivered the next morning. Phew....I thought, until I unpacked it.
The first thing I noticed was that there was zero documentation included for either the charger or the battery. I presumed I could download them from the "my orders" section of my EM3ev account, but no - nothing available & no links anywhere else to download them. The second thing I noticed was that when lifting out the charger from the well packed box, a disturbing rattle could be heard coming from inside. This was of great concern, it sounded like something had come loose. The third thing I noticed while peeling off the protective layer on the battery was the absence of the Anderson charging cable/connector I eluded to earlier & had discussed with Joseph - it just wasn't there. This meant that the only way I could connect my solar was through a flimsy 3 pin charger plug that isn't available anywhere that I can find in the EU, or I'd have to open up the battery itself & see if I can solder the wires for the Anderson connector myself - both of these options are far from ideal. The next thing I discovered while inspecting the battery was a crack/damage to one of the corners:
Obviously this means any water resistance is gone & the probability of the damage getting worse through vibration, etc is high. So, all things considered, I'm pretty hacked off with this whole experience so far. After waiting a month for delivery I have a charger I'm scared to use & a battery I can't use due to missing connectors & corner/joint damage - plus I can't risk using the charger to charge it of course. I did manage to get the object that was rattling around in the charger out through the fan outlet eventually - it was a piece of solder:
I am however reluctant to try it out in case I damage the battery/charger - plus I can't use the battery anyway, so there's really no point in trying.
Had there been no crack to the battery casing I was prepared to try & solder the required connections myself - which was why I was going to ask the community here for any info on the internals, but finding the crack is the last straw for me I'm afraid. As of now I'm still waiting for a reply from EM3ev to my last email regarding the missing connections, but having discovered the cracked casing in the meantime I feel I have no option but to return the whole lot, so I gave them a call today & got 2 minutes of classical music before being cut off. Three times. No answering machine or anything & it was in office hours in China. Not happy.
So, if anyone here has any contact with anyone at EM3ev I'd really appreciate it if they could contact me/them here, as reaching customer support at EM3ev is just draining. I'd appreciate any input or suggestions from the community here.
Thanks for reading & look forward to hearing from somebody/anybody regarding my experience with EM3ev.
