docnjoj
1 GW
As usual you hit the nail on the head AW, but I think this was a legit one. I'll find the link and post it.amberwolf said:"Studies" and their paraphrased results tend to bother me, because they rarely include all the necessary information to draw the conclusion given in the paraphrasing (or the included information is used selectively to create the illusion of that conclusion being "correct"). In that study, what other factors were also common to the replaced ones that werent' common to the non-replaced? Were they less active? Was the weight gain noted as permanent over lifetime, or only tracked for a short time after the surgery, when the patient would have necessarily been less active and thus more likely to gain weight if they continued the same diet they had when they were more active?
Lots of possible things could be causing the weight gain, other than the replacement itself--if so, most likely there is a solution for the weight gain while still getting the replacement if you really need it.![]()
otherDoc
Here ya go. They really don't have absolute direct linkage, just the data and a possible reason.
http://news.yahoo.com/knee-replacement-linked-weight-gain-183557376.html
