Guys, a very good upgrade for our little motors, thanks for the time and effort. I'm using the E version running on 52 volts as I'm not sure whether you have kept the 12A max across the 48 and 52V firmwares. Very Bosch like low cadence rpm torque curves will suit a lot of users I would suspect.
Couple of feedback comments ( not important but desirable )
The initial startup at 0 rpm is just on the verge of being too sensitive. We have to go through a number of small gates on our routes which entails standing the bike up on its back wheel. If you knock the pedals or slightly rotate them, the motor will start ( my Fazua engine did the same ). A fraction less sensitivity would be safer in my opinion. Hill starting where you need almost instant power its very good, I guess there's a balance there somewhere in between.
At higher cadences and speeds ( unrestricted ) in higher power ( Boost and + ) if you momentarily decrease the cadence ever so slightly, the power ramps down too quickly and takes approx. 1 full revolution before getting back to the same level of power. It gives a not very smooth power output whilst say riding on flat roads with mid torque on the peddles. Perhaps slow the ramp down a tad at higher cadences / speed ?
Thanks.
