neptronix said:
I can't find anything about arlo's results, even using google.
John; can you define what doing it right is?
I was thinking about big slots.. not the 'drilled rotor' approach.
If ya got a thread link, awesome..
I did slots on my first one...too much friggin work with the dremel. At the end I worry about some of the exhaust flow escaping too early before passing over the end windings.
I'm about to ventilate my Hubmonster motor, which is roughly the same diameter as your pie. I've come up with a new idea intended to stimulate flow through the air gap too, which I'll explain fully with pics in a new thread after I do it this week. In the meantime think of your motor as a centrifugal fan. The spinning side covers make the air spin and centrifugal force pushes the air to the perimeter creating high pressure there and low pressure in the space between the windings iron and the axle. If you allow air to escape at the perimeter and intake toward the center you will have a flow of fresh air through the motor.
Optimizing is a matter of maximizing flow with centrifugal fan like placement of holes (extreme perimeter for outflow like a squirrel cage fan), interior blades to deflect flow away from the covers toward the windings creating more turbulence over the windings before exiting, and shaping the holes so the outside influences of the spinning wheel on a moving bike don't counteract the natural centrifugal flow and during the most influential part of the rotation (where a hole is furthest from the road and moving the fastest relative to the outside environment), it actually stimulates more flow by creating a low pressure region at the exit behind the trailing edge of the
blade. This last part means holes or blade-like slots that are angled for a rearward exit when they are furthest from the ground, which creates a left and right side cover. DoctorBass got the angle backward on one motor and it had heat problems, because the outside influence essentially fought against the centrifugal flow. Slots to create more of a fan blade shape would be the ideal, but the magnets are where we need to put them, which is obviously impossible. Optimization in our case means right against the lip that locks into the magnet retaining ring, because that's as close to the perimeter as we can get, and air flowing out their must flow past the windings on the way out.
An 11" diameter centrifugal fan spinning hundreds of rpms can move many hundreds of cubic feet of air per minute. We can only get a decent fraction, because out covers also support the weight of the bike so we're limited on cross sectional area we can open in the best location.
Hopefully that was a coherent and understandable stream of consciousness.
Sorry, but I'm tired, but I did a good bit of research on the subject, and my ventilated motor in use proved the concept correct. A smoke test I did showed the motor drew air into the intake below 10mph or 168rpm with a 20" wheel, and flow increases drastically with speed.
John
