Hi, I'm looking to change my motor.
I have a tridenttrike spike with 12s 8Ah LiPos and a golden motor magic pie 3.
I use it every day, It's fun but here are the small issues I have and trying to correct:
- the MP3 is heavy, an issue when I have to fold the bike and lift it (pretty much every day)
- the 20 inch wheel is really stiff, everytime I see a pothole I think I'm going to break another tire. Last time the tire got a hole. Also, I'm not sure having that much wheight in the back helps.
- the drag is intense, and I get the feeling that the motor is either too slow, making me having to 'push' the motor, or too fast, making me unable to pedal along.
I'm going to try at 24V trying to figure out if it's enough power for me, and I might go this way.
So I'm looking for an alternative/replacement for my MP3, with the following specs:
- lightweight
- able to pedal without the motor on, or actually pedal along
- I don't have much hills, maybe 2 times 5 minutes and one around 10-15 minute, but not that steep.
- not too expensive
- that would make me feel a bit more at ease regarding potholes
What got me to get the MP3 was the fact that it was easy to put in place, and that I could try and figure out what would be my prefered voltage. Also it did help push really well during the winter on slippery road and slush.
I'm hesitating between a mid-drive motor, maybe something I could mount near the bottom bracket, or a geared hub. I like the ease of installing a hub motor. Also someone pointed that even if there is an issue with the chain, a hub motor will be able to continue to push the bike. But (I'm not sure why) I feel a mid-drive is less complex than a hub, that would also put less weight on the back wheel, and might be a bit more efficient when comparing the weight. Also, if one day I change bike, the mid-drive might be easier to move than a hub, since the hub could imply to relace the wheel if it changes size.
Still, I feel geared hubs seem to fill my needs, but I'm not sure which one.
I saw the q100 or mxsus or mac or bafang ... and that got me lost ... the mac might be too expensive for me.
I'm wondering, if I get for example a 48v motor, could I still try to run it at 24v ? would I just need to change the controller ? Is there a controller that could be, like the magic pie, allowed to take from 24v to 48v ?
I also was thinking about trying to get something working with a 12v system and RC motors, but finding the right fit and making the reduction gear without tools got me lost too, maybe later ...
Thanks a lot and sorry for the long post.
- lightweight
- not too expensive
