Hey all, decided to run all the brake/shifter cables, install grips, bar end caps, etc. Here's a few pics. At this point, I am waiting for my tires. When I get them, I will mount the rear wheel I am running, x5303 (these are just mock up wheels) and install the chain connecting the rear ss freewheel to front two chainrings (two speed)......
Half twist led throttle - screwed up order - did not want the led version, but I am sure the novelty will appeal to on many.... if i run anything more than 48volts, which it seems is going to be the case, the batt meter is not accurate. probably just cover it up....
grips are oury mtb. Those plastic grips that come with the throttles suck!bar end caps are from Brooklyn Machine Works. Had these things forever - they have been on two motorcycles and three of my mtbs..
Front chainrings are 50t/34t with a suntour xc expert thumb shifter - my two speed bike. Rear freewheel is a 16t
Here's a shot of the battery area - I figured out a super stealth way to mount the case - Mt Zefal Makes a cool litttle product called the "gizmo clamp" Which allow one to mount a water bottle where there are no braze ons. I will be using these slick little devices to mount the battery case to the frame rather than hose clamps...
Close up of a Gizmo Clamp on the seat tube
Another:
One more for the gipper:
Battery tray, case is next - but i still am undecided as to power. Battery pack tray and case dimensions will be defined by what I run with Leaning towards LiPo but a123 pack construction is still on my radar. Lipo can get me 72 v, 10Ah @ 13 pounds!!!!! batts and controller can be totally sealed in the case if I go with Lipo. Probably wont make a move until I return from Las Vegas. Have a three day work trip, leaving this sunday......
Later,
Len
