GCinDC
Yep.
dan974 said:I'll check tomorrow, ...don't forget it's a 24" wheel ...
what Amp did you burnt yours ? do you have a link to a post threading it ?you will burn it out quickly at anything at or over 20s lipo. if using a 12fet , you might be ok. Ive burnt two of those, one at 80v one at 100v with 18fet lyen
dan974 said:do you think I can put 280A burst in the XT150 and how much will handle the motor wires ?
dan974 said:...to answer, I would love to be able to go uphills...pedalling is not an option as I'm use to it....if it's not possible even @low speed I would stay on the costal arear and take only "flat" forest loops :wink:
it was before landing on E-earth realityGCinDC said:sorry, maybe i'm confused. i wasn't sure where you were with amperage:
and for some reason, i'm thinking you wanted to go UP the DH tracks! and then go back down them... going steep uphill is a motor cooker! but then i searched this entire thread again and found this:dan974 said:...to answer, I would love to be able to go uphills...pedalling is not an option as I'm use to it....if it's not possible even @low speed I would stay on the costal arear and take only "flat" forest loops :wink:
ok, I'm aware of it, but what the difference, technicly ? comparing to Crystalyte/chiness ones, where do they go usually ?icecube57 said:Get a speed switch from Methtek. It sits inbetween your throttle and the controller.
dan974 said:ok, I'm aware of it, but what the difference, technicly ? comparing to Crystalyte/chiness ones, where do they go usually ?icecube57 said:Get a speed switch from Methtek. It sits inbetween your throttle and the controller.
plz try to explain when posting advices or recommandation, as an engenering teacher, I'd like this thread to help me growing my knowledge and other people in similar quest...
dan974 said:6 packs had 1 or 2 cells 0.01V of difference (3.85V) and only one pack was a little difference one ..3.82/3.83 others 3.85 seams good
Do you guys would recommand 2 full cycles of charge/decharge before 1st use ?
lyen sells an ebike tester which is great to quickly identify if a hall or phase is dead. but this won't help w/ combination. for that, use pencil and paper and write out each combo you try. or do the research to find the combo for the same motor/controller combo. you are using kelly now? (ps. black & red hall wires must never change position! :wink: )dan974 said:Hey do you guys know a tester to wire the motor to the controller or do you check the multiple combination until it's smooth ?
if it charges each cell at 8A, i think you're charging at 8A x the number of cells. but i'm still behind on that thread... i would charge at less than 8A to start...dan974 said:when you parallell charge with the BC168, those it still charge @ 8A ?
the bigger power supply the better... for its sake if nothing else. the charger doesn't care about capacity, it will charge until it's done (unless you've got timers set up, etc.)...dan974 said:do we need to put a bigger W power supply if we connect more // packs on the balance board with Y cables (8 x 8000 mAh ZIPPY ) ?
