$32-00 doesn't seem excessive.... I should imagine the shipping would be more than thatcrossbreak said:Looks like these GNG inrunners are also available at mr. tao: http://www.mistertao.com/taobao-products/taobao-item-18586248326.html
So is this actually the same motor with just a different driver , same spec/same dimensions?Miles said:$32-00 doesn't seem excessive.... I should imagine the shipping would be more than thatcrossbreak said:Looks like these GNG inrunners are also available at mr. tao: http://www.mistertao.com/taobao-products/taobao-item-18586248326.html
Cool, Thank You !crossbreak said:So is this actually the same motor with just a different driver , same spec/same dimensions?
At least it seams so. No Chinese ever says what he sells, they always say: "look at picture I sent you". So you dont really know. BUT it is rated for 3000rpm@48Volts which fits and has the same dimensions assuming from the pics.
LightningRods said:I have the laser cutter lined up to cut the adjustable sheets. I will also make the sheets longer a la Christer to make room for larger sprockets/pulleys. Once I have my kit I'll create the cutting path and then get the fabrication estimate and post it here.
If you just pull the non wired end plate off the controller you solder in the shunt easily, it sits right at the end.bzhwindtalker said:Humm time to open up this puppy for me too then
I have a Turnigy watt meter mounted and monitered it while riding , I cant actually see it while pulling wheelies ect but it seemed to peak at just over 25 amps starting in my high gear ( I am running a 3 speed cassette setup with 34, 26, 20 cogs) running it up the street when I can see it.gwhy! said:just a warning, have you actually measured the current now ? as I suspect by using a staple you have basically have no current limiting at all, motor may be fine in very low gears but the controller will eventually pop...
Well I dont pretend to know much about electronics , I would install a proper shunt but wouldnt know what to ask for or where to buy it, I have also looked into installing a resister to accomplish the same thing but that was beyond my understanding. I cant really even figure out what controller to buy to upgrade ?, This staple mod was mentioned early in this thread so thought I'd give it a try.gwhy! said:a staple will have basically zero ohms , the shuts in a controller is not a normal bit of wire it has a resistance. it will be the initial pulling away from a standing start that will see the most current, once rolling the current peak will not be so much. A watt meter do not operate fast enough to catch very fast current spikes. There is the possibility that your staple do have a tiny bit of resistance and it will be all ok but I would get a proper shunt to fit into the controller, even if its to just remove the doubt.
