LightningRods
The nylon 120T is held together with four 5mm allen bolts. I'm going to try rotating the inner steel collar and see if the overall runout changes. Sometimes combined variances aggravate each other.
Its definately right hand threads, I had mine apart and tried several freewheels on it, some brands screwed on easily some didnt screw on so easily, I assume this is due to manufacturing tolerances.bee said:hey LightningRods can you confirm that the freewheel is a standard one and not "LEFT HAND" ?
I'm ordering one from http://tncscooters.com/index.php?route=product/category&path=63_114
It should allow me to mount the 65T & 80T sprocket from: http://tncscooters.com/index.php?route=product/category&path=63_89
Which should make Denisesewa's chain conversion much easier to do.
gestalt said:The adjustable sheets work great on my kit! And I finally figured out how to implement my idea to have the controller mounted with the motor and be covered up. this way I can kill two birds with one stone, shorten the wires between the controller and motor and keeping the mud and grime off of the components while still allowing air to flow. I guess that's three birds!
I can't wait till the the BB sheets are ready to get rid of that ghetto rigged chain tensioner. Then put in the cover for the drive side chain from the motor to keep those pant legs our of there. Don't know exactly what I'm going to to about the belt side yet, it's just to pretty to cover up!
LightningRods said:The nylon 120T is held together with four 5mm allen bolts. I'm going to try rotating the inner steel collar and see if the overall runout changes. Sometimes combined variances aggravate each other.
DaveP said:I propose to use Lightning Rods adjustable plates if these are still available and do away with the tensioner?
I wonder if there exists some kind of flanged thread stock adapter that would replace the freewheel
speedmd said:![]()
Just a soft mounted wheel and lightly buff. I had one. Most any will do as long as you go slowly. High speed (2500 RPM) drill will do it in reverse direction if your air tool / dremel will not spin backwards to get the back side of the teeth.
What technique did you use? Apply a little throttle and hold the brush in one spot or did you manually move the brush around the spline?
