bee
I'm going to try printing an 80 to 110t sprocket tonight that I want to try with 19t on the primary. 110t seems to be the limit for my main 3d printer, I should be able to do a 120t sleeve (in nylon!) on my second 3d printer but I haven't finished putting it together yet.
I posted the openscad source for the pulley a few pages back, check out my post history.
I'm still working out the right gear ratio. I don't think the 20mm belt will work well with overhanging printed pulleys, I think it'd be better to try that on an all metal pulley. Printed parts are weak across the horizontal layers (they can delaminate under stress).
I think my stock 80t pulley might just have too much wobble to get a good tension on the belt.
If you guys can find a source for those 120t sprockets then I can send out a few 19t sleeves to test with it.
I've ordered parts for the chain conversion because it seems like the way to go for a higher powered GNG conversion and I'd like to push this motor as hard as possible.
