Overclocker
This is a slim case but I'll be using this pack w/ a 45A controller which needs a bigger BMS than would normally fit. So some surgery is needed. I also decided not to use the 52-cell carrier to create more space
Section removed to create a flat surface. That's white PVC bonded to the Hailong w/ PVC cement. The Hailong seems to be ABS so it should be a strong bond.
In progress...
Empty case: https://www.aliexpress.com/item/Free-Shipping-E-bike-48V-lithium-battery-box-Down-tube-electric-bike-battery-case-for-48V/32763112527.html
BMS: https://www.aliexpress.com/item/Electric-motor-car-13S-48V-40A-BMS-lithium-ion-battery-BMS-Used-for-48V-20Ah-30Ah/32484213150.html
