Help with BMS in Series to create a Leaf battery
DaveDmd
usa
I need to wire up 4- 24s bms in series to produce 384v for an ev Leaf car. Can anyone help with how to wire these 4 together properly, im not understanding the balancing output as the bms only has the -P output. ITs a big problem since a 96s bms is extremally expensive for this job.
And should I use a 100 amp BMS or less since each pack is 24 x 10 cells with estimated rating of 26ah.
