recumpence
1 GW
Heh, I know what Clue is asking this for.
Ohhhhh, yes, I can see it now, Man!
Matt
Matt
No need to be sorry, why not just make a thread for it somewhere, maybe the general discussion or off topic area, maybe someone will know1clue said:Sorry I brought it up.
It's vastly off topic for the entire site. I was just hoping for one of you guys to have come across a company that supplies light weight, high efficiency variable-speed motors and controllers in the 20-30 hp range.
nomad85 said:Looking good Gary, I (and everyone else) am really looking forward to seeing your progress![]()
What kind of batteries are you planning to use?
johnrobholmes said:The HV caps are 50v rated. If you assume 10% tolerance of the caps, 55v would be the max.
I put 18s a123 through mine and didn't have a failure. That initial high voltage is what can hurt the components, so best knock down the fresh - off -the - charger voltage.
Max input is a strict 50.4v unfortunately. You'd have to get the pack to cut off at this voltage in order for the pack to work. Anything over this and your headed down a nasty path...could be immediate, could be 10 flights from now, but it will happen. I wouldn't do it. There are FETs on the market that will handle the higher voltages, but they're not quite up to par yet (and cost a small fortune). We've been testing with our SHV (90v) ESC...very hard to get a controller that handles over 50v to be totally consistent...why ours is not out yet. Basically, I wouldn't do it, and I work here.
Joe Ford
Product Specialist
Castle Creations
liveforphysics said:Beautiful battery pack Gary! Did you make that yourself? Very nicely done!
-Luke
recumpence said:sockman said:recumpence said:Wow, perfect timing!
I just finished your drive this morning (other than the belt. I am waiting on my next batch to arrive).
Are you driving the left or right side? I need to know so I can setup your FW adaptor to match.![]()
Matt
perfect!
i'm driving left sided...
That's what I figured. So, I guessed and set it up that way.![]()
As soon as the belt arrives, I will ship it.
Matt
recumpence said:Yup, arrived yesterday!
Happy day!![]()
Your drive is done and I am on to Y-Pedal's drive.
Matt
Ypedal said:recumpence said:Yup, arrived yesterday!
Happy day!![]()
Matt
* Insert Dance of Joy Smiley !!
recumpence said:Here is the deal on the clamps;
Dave and I have been talking about this. Those clamps are beautiful, but require alot of secondary operations to make (machine block, remove and flip, machine, remove and flip, machine, remove and flip, etc, etc, etc). The bottom portion of the clamp is a 5 operation part alone! So, for one two piece clamp, we are looking at $55 without material (and, trust me, Dave gives me a break on machining). So, that would be over $100 for the two clamps. However, I have a couple ideas to reduce it to 3 operations, maybe only two! I want to get the clamps down to $30 each WITH material.
Matt
