northernmike
Gary, would it fit down low?
Behold the Moby "X" =
Our hourly rate is $67.17/hr. Figure it will take us about 2 hours to do the job. We would also charge for material used....
Remember, the cost in the set-up of the machines, every time you add quantity, you are dropping your unit cost price.
100 tooth pulley would cost you $114.87, or you could try adapting one of our existing 102 tooth pulleys (closest that we have to 100) to fit your needs
How much would your 102T pulley cost bored out to roughly 2.125"?
After seeing the pictures, I wouldn’t do that, we would make you one from scratch. The problem you will run into is keeping everything concentric to the original bore. The only true way to do it is to make soft jaws (for a lathe chuck) and rebore the pulley. It would be cheaper for us to build you a new pulley to exactly the number of teeth you are looking for.
liveforphysics said:Looking good Gary, your projects always look great!
If you get a cheapy harbor freight hand grinder, and a bench vise, hacksaw, and a good smithing hammer, you can fashion pretty much whatever pieces you may need. Not quickly, but none the less you can have great pieces.
I would like to offer you free welding up of any parts you mail me, and I will mail it back free too! So, if you happen to see some part in a project where you fashion a couple pieces of steel, aluminum, bronze, copper or even titanium, and mail them with an explicit diagram with good measurement points and things, I will happily weld them for you and send it back to you.
I think the way you are doing this project might work out just fine, or it may have a little too much flex that could cause the chain to hop. It's really something you just need to try out and see. But if you happen to find yourself ever thinking it would be slick to have some pieces of metal joined together, I will happily help out however I can.
Best Wishes,
-Luke
GGoodrum said:Mitch, those parts look just like the Cyclone bits I just took off. None would do anything for this setup. How would you bolt the "foot" to these?
GGoodrum said:I'm actually pretty happy with the current setup, at least until I've had a chance to finally do some testing. I didn't get time to work on this tonight, but I will get back at it tomorrow.
-- Gary
The L-shaped stock you called wings might look OK if you used the holes originally intended for U-bolts to bolt to the flat-plate. Bolted to a plate they wouldn't look like wings hanging out from the top-tube.GGoodrum said:Tonight I'm going to try and figure out how to "adapt" the foot so that it can be secured to the bar. Like I said, I think the easiest way, at this point, is to drill and tap four 1/4-20 or M6 holes on the bottom of the foot, and then add four matching slots in the bar. That will allow the whole assembly to slide front-to-back enough to tighten the chain.
Yes, that has to be the punchline of a joke about turkeys, but I haven't found the rest, yet...GGoodrum said:Yes, the "wings" look less odd when on a plate.![]()
I hear you.recumpence said:I would hate to make them and be stuck with many of them, etierh because the drives are already mounted, or because the bore is wrong.
Matt
oofnik said:I hear you.recumpence said:I would hate to make them and be stuck with many of them, etierh because the drives are already mounted, or because the bore is wrong.
Matt$90? Really?
Maybe I'm just blind/deaf to cheaper and simpler mounting options but the idea of these clamps really interest me.
Perhaps when I come visit you next time I'll bring my frame with me and we'll figure something out together.![]()
revkev6 said:recumpance,
first post here, I read about your electric recombant on recombants.com and followed the link here. I was looking at a larger, cheaper RC motor to use in this application. it lists for 149.95 USD.
This is to swap out the cheapy bearings, and swap in the class 7 bearings I ordered today. They were $55/bearing for the class 7 precision bearings! Each motor uses 3.
So, working with the motors today, I decided that the metal used for the shafts is not really as strong as I would like. It seems to be mild-steel.
All ready re-epoxied the magnets long ago.I also put a drop of high-temp epoxy in the center of each set of the copper fill to ensure the windings don't decide to wiggle out into the rotor magnets.
In this motor, each magnet sits in a neat little machined recess, so it's nice that they have more mechanical support than many of the china motors.
So far, in these motors, the bearings are crap, the shaft is crap steel, and the snap-ring is fashioned from modeling clay. By the time you spend $200 to upgrade these pieces on the $130 motor, you are double wishing that CNCguy would hurry up and release his uber-motors that are all high quality with massively oversize bearings.
recumpence said:I have a finalized design. But, they are still going to cost me $90 per set ($10 materials and $80 machining) because there are 4 parts for two complete clamps with mumtiple operations each..........
I can have them manufactured, but I need to know there is a market for these and there are a number of different frame tubes to contend with.
I need to have a minimum number of them made to get them in production (probably about $800 worth).
Matt
The Flair Leg BRACK-IT design provides a secure fit that locks each leg in
place on round poles or mast arms of almost every diameter.
