So I'm going for the "Bike Rack Shock Mount" idea.
The added benefit is that it eliminates the uncertainty about where everything fits.
Enough for today... that's 3 hours of cutting, grinding and welding.
Note the "cute" little rounded end tabs.
That's mostly for show but you might attach a tie down to it.
We are talking an ounce here if even a full ounce and by welding inward I was able to use a really thin cross member and get it to actually weld without melting.
The usable rack area will be about 5.25" wide and somewhere around 10" long which will be a nice rack.
Might as well use it for something.
This part here will be on it's fourth recycle and that's after it was created for something else.
The plan is to blend this part and the "Bike Rack Shock Mount" into one unit bringing several different mounting points on the frame together.
When I bought the shock I had no idea how stiff it would be ($25) and the very aggressive 30" swingarm obviously means there is a lot of leverage if you mount the shock inward.
But an extended frame that doubles as a rack is not so bad in the weight department because what really would have been required for a forward mounted shock would have been a
HEAVIER SHOCK.
So thinking only about weight I'm probably ending up lighter this way... a light shock made to absorb less leverage.
I'm guessing this shock is three or four pounds just by feel.
Looks like I picked up a little from this image posted earlier.
That looks like it could be longer than a 55" wheelbase. And it has a massive bike rack.
