badgineer
🔋 Established
Hello ES
I've been working for the pas 2-3 month on an ESC and want to publish it here.
I am also grateful to mxlemming for his support - sometimes hands on, sometimes opinions and advice.
We're calling it the MP2 ESC. Multi Platform, Modular and Powerful ESC.
The design aims were the following:
Additional features:
And what is good hardware without good software?
So the nicest feature of all might just be the fact that the "multi-pill" compatibility should make it usable with quite a few existing open source projects.
I think it is mostly done now, hopefully soon to exist physically. But im still fiddling with it. Cant. Stop. Microoptimising.
Link: GitHub - badgineer/MP2-ESC: Multi-Platform, Modular, Powerful ESC
Here Some Pics.
Update 13.11.2022:
New v0.3 released with multiple small improvements. (more caps - both mlcc and electrolytic, also now solderjumper configurable for 16, 20s and 30s batteries. For 30s batteries mlcc caps need to be replaced.)
Update 13.09.2023
New v0.5 released (merged to main but not tagged yet) with multiple small improvements and changes
Feedback is appreciated.
Br,
- Modularity. Takes "pill" modules, instead of MCU as in bluepill, blackpill, etc. DC-DC are also modules.
- Wide compatibility. Should actually be able to take both pills, despite the slightly different footprints
- All standard footprint parts. No proprietary fancy parts. Part shortage? No problem, everything is easy to replace.
- Power. 18 to220 FETs, should, if everything is super well done, be able to take 300 Phase A for short periods of time.
- Low cost. Uses mostly low cost parts, or is low-cos-part compatible. PCB is 100mm wide, should be cheap on JLCPCB.
- DIY Friendly. Has SMDs on only one side, can be ordered with SMDs pre-assembled. Only TH parts need to be soldered by hand.
- Easy to access debug pads for probes.
- Hardware overvoltage protection vor VBus
- Hardware overcurrent protection for phases
- Designed for 20s 72V batteries, easily customizable to 16s or 30s.
- VESC with GD32F303CG pill (Netzpfuscher mod, note CG)
- VESC with DIY F405 "Pill" (GitHub - davidmolony/F405_pill: F405 Pill for running VESC based motor control from a Black/Blue Pill footprint)
- EBICS with F103 Bluepill (Stancecoke)
- SmartESC V3 (Casainho)
- SmartESC V2 (Netzpfuscher/Koxx3)
- MESC with F401 Blackpill (MxlemmingFOC)
- STM32 Motor Control Workbench (F401, F103)
Here Some Pics.
Update 13.11.2022:
Update 13.09.2023
Br,
