rg12 said:Nope, I don't know anything about the cells...even the capacity is unknown until I checked (2000mAh charged from 3.25v to 4.15v), got like 80pcs of them...
redilast said:rg12 said:Nope, I don't know anything about the cells...even the capacity is unknown until I checked (2000mAh charged from 3.25v to 4.15v), got like 80pcs of them...
Do you have any pictures of the cells? Or can you at least list any markings on the cells?
If you have the ability to measure the internal resistance of the cells that would be helpful. Alternately you could do a 4-5A discharge to see what the voltage sag is like and that will give us an idea as to the rated discharge.
Also by far most 18650's on the market are laptop grade cells and are rated at 2C. Power tool cells make up a lot less of the market.
dogman dan said:Likely they will not perform well till you get your actual c rate in use below .5c. That has been typical of laptop cells in the past.
So 20amps, that will take about 40 ah of this stuff. You might get away with less, since a 20 mph cruise only takes about 15 amps.
With a half decent RC charger, you can test voltage drop during a discharge, then calculate IR.
rg12 said:One little question, my charger (Turnigy Accucel-8) is not discharging properly.
For example, if I set the charger to do a single cell discharge to a set voltage of 3.0v then for some reason it stops alot before (around 3.4v) and then if I want to go lower than that I need to slow the discharge to about 0.1A to get to 3.25v and that's it, that is the max that it will go on any cell I tried including Samsung 26F, Panasonic 3400mAh and some cheap cells.
It's just that it gets to the 3.0v by sagging and not by actually getting the cells there and then it stops.
Any ideas what to do?
rg12 said:About the charger, yes that rebound is the "sagging" when under loads the volts drop a bit.
The problem is that even with original high quality cells it drops about 0.3v and stops the discharge 0.3v before it needs to.
That way I can never discharge to 3.0v and even discharge to storage voltage stops at 3.88v which is not low enough for storage.
About the C rate, will do, thanks alot.
Roy
