migueralliart
It could've been a motorcycle. I think all these apps do is use the GPS to make the calculations.
That motor must be a BEAST! Enjoy it buddy.
Trackman417 said:Alrighty
So far I am 2-0 when it comes to racing mopeds.
I went into my LBS to see if they had a tire that matched my rear tire, since I like things to match. And they were pulling out the titanic of all mopeds out of their shop. My only comment was how massive the thing was and the guy responded with; "It's the fastest moped I have ever riden"....... My thoughts were to see if his comment was actually true, I asked him to race my bike.
Long story short, I end up tailing him until we find a red light to let the drag race of the century begin. The light turns green and I am easing into the throttle, so I don't land on my ass, and the guy looks like he is just standing still. I end up waiting for him at the next red light and same story. I had to get some stuff done at my bank so I after the second drag race, I wait for him at the side of the road and his only comment was "This thing is so slow."... I think I may have destroyed his confidence in what he thought was the fastest moped he ever road.
On another note, I found an app called "Strava Cycling". It's where all these cyclists go out on set portions of road and their phone logs how fast they did the portions of road in and ranks them on a leader board. Sounds innocent enough..... Until I find that some "cyclist" went 41 mph down a stretch of road that is right behind me.. That road is long and straight, but it is not flat enough to be riding a road bicycle with puny tires and frame, 41mph down there. I have another set of batteries I can hook up in series for 98.4 volts hot off the charger to beat this guy
. I guess the H4065 does need a good break in 8). It never does get too warm from any of the 3kw I throw at it so how about 4kw?
Before I do get series the other battery pack and race this guy, how likely is it that a cyclist can keep 40mph?
migueralliart said:It could've been a motorcycle. I think all these apps do is use the GPS to make the calculations.
Its got to be Lance Armstrong.That's one fast cyclist trackman. He would give me a run on the Bomber.
Rix said:Just a suggestion, before you go toning down the throttle response, see if the forks help with control. I love my Bomber, but would love a throttle that would hit down low hard so I would have to work at keeping the front wheel on the ground. Oh well.
Rick
EdwardNY said:Hey Trackman,
where did you buy your 4065 from?
When are you going to buy a cycle analyst? Do you still think it needs more progress?
Trackman417 said:...I may start a new build thread, when I graduate college, where I copy everything Hillzofalp did and convert a rather unsuspicious looking moped and use one of John in CR's super ultra power plasma spitting motors. But we will see what new, and hopefully awesome, technology comes out in 2 years time :wink: .
I think me and my bike are a TOTAL of around 200-250 poundsJohn in CR said:We'll have special frames long before 2 years, and AFAIC the goal for total bike weight with Hubmonster is 150lb or less including the battery. My SuperV is 137lb with about 10 extra pounds on the swingarm than HoV's Farfle swingarm, and I've got 2.2kwh. Shoot for significantly less all up weight with rider than my 400lb so you can enjoy staggering performance with no system stress. For 9 months I was running 16kw peak at 74V nominal and I was right at the limit running a stock motor with 65mph top speed, and sure performance was incredible, but power to weight is everything and 50lb less makes a big. If you don't believe me, put 50lb in a backpack and go ride your bike.
If you're a more normal weight person, then you can build a stronger bike closer to a moto, but with some lighter components that motorcycle companies can never use because they sell to the general public...stronger but still much lighter than my all up load. Follow Farfle's lead in that regard, because he's definitely on the right track.
John
So I am narrowing down on the weight and 250 is too much. I went to the gym yesterday and lifted 85 pounds worth of weight.... And there was no way my bike is 85 pounds, I was reaching my limit with the 85 pound weights rather quickly, so I will put the bike at maybe 55-70 pounds now. So that would bring me and the bike somewhere near 210.Rix said:Sweet ride and sweet bulk charger. 250 for you and your bike. I am at about 356-360 bike and rider weight combined. Put 100 pounds on your front fork and your wheelie problem is a thing of the past.
Rick
Yeah, that was the case originally. But it was too good an offer to miss. The original forks were Walmart quality and I would not know if they were suspension forks if I road blind folded over small bumps in the road. They did not do there job rather well. The RST R1's do limit my turning radius but that's only when I steering the bike while I am walking. Even at 8 mph, I can't even get close to turning the bike to where the fork stops me from turning. There is a huge difference in the quality of the ride. It feels like a giant cushion up front, which is amazingEdwardNY said:What made you upgrade your fork? I thought the general consensus was that you need to keep similar travel as your original forks or what your bike was designed for. Is it not too much travel or limit your turning any? Does it make a big difference and worth the upgrade to go with a double crown fork like that?
What is the wattage of that bulk charger?
I'll try to make it work :wink:Rix said:That is a weird axle. Definitely was intended for Ebicycles.
Rick
Rix said:Exactly! Whats not to love. I think running 24s at 40 amps would be a great and reliable combo for your 4065 and 26 inch rims. Because of your light weight and the light weight of your machine, 4000Watts will run like a bat outof hell and not be over volting/current things much at all. Hyena was seeing 78KPH (47-48MPH) with his 4065 on 24 MTBs, There is a possibility of you could be breaking 50MPH with the narrow 26s you are running. but a gaurenteed 46-47MPH is a definate. Cant wait to hear about after you get it going.
Rick
Trackman417 said:Yeah that did not happen when I ran the 4065 at 100volts today. I was just scraping 42mph at WOT. hmmm, I think my three speed throttle switch may be interfering with something, either that or my circumference on the CA is out of wack.Rix said:Exactly! Whats not to love. I think running 24s at 40 amps would be a great and reliable combo for your 4065 and 26 inch rims. Because of your light weight and the light weight of your machine, 4000Watts will run like a bat outof hell and not be over volting/current things much at all. Hyena was seeing 78KPH (47-48MPH) with his 4065 on 24 MTBs, There is a possibility of you could be breaking 50MPH with the narrow 26s you are running. but a gaurenteed 46-47MPH is a definate. Cant wait to hear about after you get it going.
Rick
So much for a guaranteed 46mph![]()
Need to get my charging situation set up though. It is not, as you say, efficient. Pics to come tomorrow. Get ready to start critiquing on how much of a trip hazard my set up is.
Rix said:100 volts and 42MPH, I would have to say that the 4065 has the exact same stator wind turn count as the 5405 then and the 5403 would be the same as the 4080. That's makes sense.
Rick
If you look at 65kph and convert it to mph you find it is right around 40mphscriewy said:LoL trackman so much anticipation for 47mph, and then SPLAT !......
why you got the 4065 instead of 4080 if you wanted 47mph to keep with the traffic ?
My no load speed is 45mph, at 80 volts, which is 72kph. Which is real good, when you think about it. Compared the H3540 that had a no load speed of around 60mph and lost 20mph of its top speed when loaded. The 4065 only lost 10mph.scriewy said:what's your no load speed 100-110kmh ?
At 84 volts my top speed is 37 mph and my amp draw is around 16 amps or so. At 100 volts the amp draw at top speed is 27 amps.scriewy said:what was your amp draw at constant max load speed when you 'almost' (backround gigles) kept up with the traffic ?
