Manbeer said:
Looking to compile a list of hubs that have 10mm axles and can properly recess into most dropouts without filing. from what i gather from Justins extensive research and documentation, it seems the bafang g310 and the GMAC will properly fit into most bikes without filing.
Pretty much any hubmotor intended for bicycles has a 10mm axle, as far as the *flats* go, so they all fit in common 10mm bicycle dropouts. Larger stuff intended for scooters and motorcycles and the like may use wider spacing between the flats, or even ones that arent' parallel between axle ends, or something else entirely.
But none of them have 10mm *diameter* axles, becuase if they did, there would be nowhere for the flats to be, as it would be entirely round. So they will all be "taller" than the axle the dropouts were intended to fit--whether that means a problem requiring filing depends on several things--the first being whether the dropout is deep enough to accomodate the extra mm or two, and the second being whether the end of the dropout is rounded to a 10mm axle's circumference, or if it is a generic curve, etc.
The smaller / older motors used 12mm diameter axles, which would be 1mm "taller" than the 10mm dropout was designed to hold. Sometimes that's not a problem, sometimes it is.
Newer / larger motors use 14mm diameter axles, whcih is 2mm "taller", and is more likely to be a problem.
For motors that don't use axle flats to transmit torque, but instead use an integrated torque arm (Heinzmann, potentially the Grin All-axle motor, perhaps other customized motors from Grin), they probably have 10mm *diameter* round axles to better fit traditional bike dropouts. (or in the case of the AAM, such an axle can be created and installed).
Even newer motors (from Grin at least) use thru-axle type axle mounts with integrated torque arms.
There's also ones like the TDCM w/IGH that Grin sells that I think also use an integrated torque arm but *also* use axle flats. But I couldn't find an axle size listed on their info page for that motor.
One thing the Grin site could use is the ability to sort motors by axle OLD / length, as well as by axle diameter.
