ccihon
Latest update - I swapped the 9-speed derailleur/cassette for an Alfine 8-speed hub. With the attached 20T sprocket, I am getting a very similar set of gears I had with the previous 11-32 cassette. I kept the shift sensor, and am using the Alfine chain tensioner as I have "near" vertical frame dropouts. This also let me keep the same basic chain length, easing return to original setup, though doubt I will go that way.
Mt main reason to move to this was to allow shifting while stopped, or nearly any time really, and to eliminate the noise and chatter while turning corners in lower gears, which was induced by frame/hub twist that tended to cause chain misalignment in the bigger cogs.
TBD: reliability with the BBSHD - I treat it fairly gently and so far it shifts surely and silently. The hub is also silent while coasting, which I appreciate. Common logic is to use the much more expensive Rohloff or other IGH with this much torque, but others say this one will do just fine for my application. I also dislike twist and trigger shifters on a trike, so the bar-end that works with Alfine is a plus.
