Abagrizzli
- Joined
- Dec 25, 2014
- Messages
- 98
Hi guys, need your help again.
Paul offers this battery, which I found very attractive for its weight and dimensions. Paul says it will be compatible with the BBS02 750W 48V.
SDI INR18650-25R
Configuration: 13S, 4P
V(nom): 46.8
Ah(nom): 9.8
Whrs: 458.64
Weight: 2.5 kg
height (mm): 75
width (mm): 83
length (mm, incl. BMS): 257
Now the question is - what this battery will be good for? Range, speed and work hours?
Also yet another question - is there a way to wire a hydraulic Shimano XT brakes to the motor?
SDI INR18650-25R
V(nom): 46.8
Ah(nom): 9.8
Whrs: 458.64
Weight: 2.5 kg
height (mm): 75
width (mm): 83
