bowlofsalad
Hello,
I've been considering the idea of putting a old bicycle tire as a tire liner ('the system'). I have been pondering on the various options for tires as a tire liner, because surely there are tremendous amounts of variation in options and how they would effect your ride. Originally I was considering the idea of using tires with shaved down knobbies and no kevlar belt, so basically a very light weight mountain bike tire. This might produce a really extreme gap inside of the tire. People seem to say that marathon plus tires are very good at preventing flats. The idea behind that is that they use a very tough material and a lot of it to make the tire thick and hard to penetrate. I imagine that this tough tire insert as it may make the tire very unforgiving to bumps and vibrations. I imagine that instead of using something very hard, to use something very soft. Others have used things like thorn proof inner tubes as liners. The issues with pretty much every concept is their weight.
I imagine it might be the best of both worlds to use airless tires that are made to be like they are very soft as tire liners. I was inspired for this concept when looking opening a new spindle of blank discs. The spindle had a round foamy thing with a hole in the center, sort of like a washer. I doubt this bubbly foam stuff would be suitable in bike tires with the amount of pressure that would be pressed against them, but that might work too, who knows. Basically, I am thinking that very light, bubbly material of appropriate thickness might be the ideal tire liner.
While I imagine a tougher liner might help in some situations, the tougher stuff may still be punctured by longer things as it gets hammered into the tire regardless of how tough it is, and that the only thing that will prevent a flat is a larger gap between the what is going through the outside of the tire and the inner tube. Something else that might be hard to explain, I imagine if there are little bubbles in whatever is being used as the tire liner, that smaller sharp things like pieces of glass would stay in the tiny bubble, unable to dig deeper, a theory that could be wrong.
Maybe I am being silly and trying to reinvent the wheel and should just use some thorn proof inner tubes as tire liners. But the concept sounds good to me. A soft, flexible, somewhat thick, lightweight tire insert.
