Samd
I wouldn't have thought the stock bearings to be too bad - did you bother with yours allex?
Samd said:I wouldn't have thought the stock bearings to be too bad - did you bother with yours allex?
Allex said:Those are 12awg all the way, but first bit is not silicone but heat shrink only.
As for the connectors, use xt150 instead.
You can have the stock hall wires, no problem.
Rix said:Samd said:I wouldn't have thought the stock bearings to be too bad - did you bother with yours allex?
Sam, Allex did that at my request. I don't know how the stock bearings are, but I wanted this motor pimped out to the Max, hence the upgraded phase wires and SKF Bearings. I don't know if Allex did that to his motor. Hey Allex, whats up?
ewinters said:Can we just open it and spray high temperature black ink (the kind used on exhaust pipes), to add rust resistance?Will the solvent on the spray damage the varnish on the windings?
korpin said:I just purchased an MXUS motor and wanted to ask...has anybody just used the stock wires that come with motor?..did it work?
teslanv said:I upgraded the phase wires on my 3T winding to 12AWG PTFE, but I would not bother to upgrade a 4T or slower winding. The easiest solution is to cut the phase wires close to the axle, and splice in some 10AWG Silicone wire from there to the controller. This would get you ~80% of the benefit of upgrading the entire wire run through the axle.
I would say that the stock 2.5mm2 phase wires can handle up to 100A of phase current for extended periods without melting the insulation. - If anyone has ran more than 100 Phase amps through the stock phase wires, or if someone has actually melted the insulation on stock phase wires, please report your findings. :wink:
