bellfador said:![]()
[/quote
DCIR = (U2-U1) / (I1-12)
Maybe now is easy to understand.
[/quote
Punx0r said:If you have a 13P pack and a 30A BBSHD, why would you be looking for cells capable of a 30A continuous discharge? You actual discharge is going to be less than a tenth of that...
bellfador said:VTC5A is added.
2460 mAh from SkyRC B6 @1A;
2400 mAh from the battery tester 0.9A / 8A;
Weight: 47.34 g
Matador said:?.......
But I'd like to know what's the best 30A/cell 18650 out there. Some cell truely able to handle thoses 30A per cell continuous load without heating and loosing capacity. Having the lowest possible DCIR... Still in the 30A/cell-realm, there's probably one that of cell that has the best value, the best usefull life and still a reasonable mAh rating (range).......
n
Hillhater said:No such cell exists to suit all your expectations......
...but probably the closest is the A123 M1 which has the life and powerability, but sacrifices capacity.....and cost.!
Hillhater said:Sorry to revive an old post, but i was just refering back for info and noticed on the VTC5 test something odd..
A) you seem to have increased the charge voltage to 4.2v from the 4.1 for the previous cells ?
B) that cell also seems to last nearly twice as long (7000s) as any of the previous tests ?
Did you change the test protocal/ timings somehow ?....longer time between discharge pulses maybe ?
......but that would influence the temperature build up ?
Weight: 47.34 g
