bumpyrider
- Joined
- Aug 20, 2009
- Messages
- 34
It's vague info perhaps it's peak figures, it's in wheelie range, 2kw/kg and NM is relative to peak rpm. For the moment Its just a good sales video, no technical info there?What is power and torque density?
As long as they pot the corrodable parts, and use bearings that are either "sealed" or lubricant packed or "uncorrodable"then I'd guess the primary problem to worry about is particle ingress along with the water that cause wear on surface (including where they builds up, and produce wear on surfaces that normally wouldn't touch each other).
Exactly what I thought when I first saw all this stuff, I'll admit it could potentially be cooled better than other hub motor constructions but I'm not sure that is the best solution for that problem considering the other issues with the design. I think their power claims are basically cheating peak vs continuous power, like sure most motors can put out much higher power than rated continuously in some ideal conditions but you want a motor that will do it's claimed power in most conditions.In the end, it's a hub motor and will hit the same reality as every other hub motor. There, done.
don't know if the weight can lean into bends because of centrifical force. Perhaps Bionx can be compared for hub size? Plus what would the pedals join up to?This rim-sized diameter can make the motor superior to a mid drive in pretty much every way. It would be great for an ebike.
Let's say you made a regular hub motor like you describe but made the diameter almost as large as the rim. Sure you'd get the benefits of the large diameter and simple small bearings but you'd lose the main benefit of the donut motor. That being the highly effective air cooling thanks to the exposed stator and fins.The optimized solution for hub motors is what large diameter direct drive hubs already use, with a spoke supported stator fixed to the axle, and a side cover supported rotor turning on smallish axle bearings, with only enough surplus diameter to accommodate a cable conduit.
There's various people here (including Cowardlyduck, IIRC) who have long-term run hubmotors with not only vented side covers, but actually fans inside the stator to draw air thru them, and debris hasn't been the issue one would expect.This isn't possible in a conventional hub motor because if you vent the side covers both the rotor and stator are completely exposed to the elements.
