Jamessaki
i feel like after returning bikes and buying new ones after 5 times its becoming a bit to much.
docw009 said:Jeez. It's got one lever squeezing two v-brakes. How is that going to work?
Chalo said:The front is actuated in the usual way by the cable; but the cable runs from a special sliding brake pad rather than a lever. It's really not a bad system-- though as I said, Walmart probably cheaped it down until it doesn't work worth a damn. They do the same to normal brakes, though, so there's no real advantage in reverting the brakes to normal unless you also upgrade them.
Since Surestop appears to have staked their business on the Walmart deal, there's a decent chance that the equipment is better than usual.
It is mostly a matter of expectations. I bought this bike for my Golden Motor Front Hub a couple of years ago (on sale for $150).Jamessaki said:But everyone is telling me to change my bike so what's the point of asking about this bike
LewTwo said:It is mostly a matter of expectations. I bought this bike for my Golden Motor Front Hub a couple of years ago (on sale for $150).Jamessaki said:But everyone is telling me to change my bike so what's the point of asking about this bike
https://www.amazon.com/gp/product/B00O6HGBP6
I did NOT try to use it riding trails or other challenging terrain. It worked and got me back and forth where I needed to go. My problem is that I wanted something lighter .... now I realize that some weight is not necessarily a bad thing. A little weight and wider tires gave that bike more stability on Houston's poor quality pavements that CF Frame road bike I am currently riding.
Chalo said:The overall range (ratio between highest and lowest gears) of the most common 3-speed hub is 186%. The overall range of the most common 7 speed freewheel is 200%. Don't be dazzled by the number of gears.
lester12483 said:Go on craigslist and buy a used ebike for $400, build a new SLA battery for $150. Total = $550
That and it being dogman that's saying it are as good assurance as you can expect to get.dogman dan said:I think you did fine, and don't have to listen to everybody else talking about what they need. You are good to go for what you need.
... Bear in mind,, I HAVE ONE. THEY DONT.
Jamessaki said:I posted a steel frame bike but no responses
So IL look for a steel 7+speed bike that's got either suspension or good torque armsChalo said:Jamessaki said:I posted a steel frame bike but no responses
I hate to split hairs regarding BSOs (bicycle-shaped objects), since they're all best avoided. But if you must get a BSO-- stay far, far away from Roadmaster, Magna, and Next. Those are not redeemable. At all. They are just one slim cut above walking barefoot instead. They rank below walking in passable shoes.
999zip999 said:Where's the battery going to go. When making a homemade ebikes check to see what shift letters you have with brake levers you have are they connected as a one-piece unit where you going to put the throttle where are you going to put your display look at your handlebars for your at all out where's the battery going to go where's the controller going to go you do this before buying a bicycle. You are now going to be electrical bike technical engineer. Get your tools and fall in love with your new job
That is the only way to achieve building a good cheap bike. Recycle, use everything that you see as potential component to succeed. It can be very cheap. We saw some here, who did build entirely with recycled parts from the junkyards. You have 1000$, don't consider it as a limitation but rather work to build using the least of it. :wink:999zip999 said:...You are now going to be electrical bike technical engineer. Get your tools and fall in love with your new job
I did have a Roadmaster Granite bike converted to electric and it was decent for a first ebike. The steel horizontal rear dropouts are much better for a rear motor than for example thick aluminum vertical dropouts.Jamessaki said:lester12483 said:Go on craigslist and buy a used ebike for $400, build a new SLA battery for $150. Total = $550
The only used bikes are 50+ miles and not close to 450 closer to 1500
How's this 1. https://ibb.co/mZDbza
Chalo said:If you're happy with less than 20mph, you don't need any suspension at all, front or rear. For a budget build that actually holds up for a while and is an appropriate size for you, maybe consider something like this, instead of a BSO:
http://www.bikesdirect.com/products/gravity/swift-flatbar-hybrid-xiv.htm
That's about as cheap as an actual new bicycle gets. It still needs to be set in order by a knowledgeable person so it doesn't grind itself up.
In your price range, don't worry about steel vs aluminum. Cheap steel bikes are likely to be soft enough that a hub motor axle bends the dropouts and spins out anyway, if you don't use torque arms.
Chalo said:Sure, it's only a matter of the compromises you're willing to accept. At some point down the price scale, the thing either doesn't work right most of the time, or requires you to repair it very frequently, or both.
However, I suggest that if "one size" pants wouldn't suit you, a one-size bike won't suit you either. Most one-size BSOs are approximately right for an average adolescent or a short adult.
