jonescg
I've got a LiPo build thread in the for sale section which folks are welcome to check out - It's a long running study in the best (or rather, least worst) way of assembling a LiPo pack with multiple cells in parallel.
I have recently started building battery packs using cylindrical cells because sometimes, they are the more appropriate option. Of course for eBikes you can just spotweld them together using hexagonal capture kits that click together and nickel strips, and the ones offered by KarT_PS are prety good: https://endless-sphere.com/forums/viewtopic.php?f=31&t=92223
But I am building big batteries fairly often, so I've started using capture plates and bus plates, and this will allow me to make 50-100 Ah packs with lots in series. So this is my latest effort:
Unfortunately my old work who bought a wirebonder closed up shop, so I can't get them wirebonded by robot. So I will resort to spot-welding. Nickel plated aluminium will take a spot weld, but in all fairness, soldered connections to the busplate are probably a bit better. The nickel strip would then be spot-welded to the cells below.
The goal is to build four of these for the Prelude conversion. They won't be liquid cooled - after the pouch cell pack was totalled by a coolant leak, I have decided this will have to deal with the heat. But it will be fully potted inside a polyurethane encapsulant which will make it waterproof and rugged.
I'll add more photos as I go along.
