I think the foil crimps would be the thing for Lipo pouch cells with aluminum tabs (or A123 prismatics). Aluminum is hard to weld or solder to.
NetPro said:That's great news!
Will definitely go the 3S route; I mentioned the 2S because there was an older post indicating that a 2S was recommended.
In fact, Unless I hear otherwise, this is the one I plan on getting:
http://www.hobbyking.com/hobbyking/store/__26453__Turnigy_nano_tech_1500mah_3S_35_70C_Lipo_Pack.html
Would it be safe to get a pack with more Ah? They are so inexpensive!
Thanks riba2233 and Allex!!!
riba2233 said:That's really nice, thank you for showing! That's pretty large pack too
Allex said:Are you flying to the moon with that? The pack is huuge for such low powered motor. The range will be around 90km pedal to the metal that is.
This is where it gets confusing for a newbie like me.Mondo said:You do realise that is only a 1.5 amp hour pack. You need 10 in parallel to make a 15Ah pack"
riba2233 said:Use 3S 20 Ah nano cells and that should be it!
NetPro said:riba2233 said:Use 3S 20 Ah nano cells and that should be it!
Thanks riba2233 for the specific number you provided. That's what I was looking for!
However, one question remains, forgive me for being a bit slow :? , but, when I go to the hobbyking site, the largest nano pack I could find is 6000 mah.
Do you mean I should put three of these in P to achieve 18000 mah? (Or any combination of similar packs to get up to 20000 mah?)
I think once I get the answer to this I am all-set to give it a try.
Needless to say, thanks a bunch for your patience
fullonoob said:is it ok to use 4S?
bigbore said:fullonoob said:is it ok to use 4S?
4S is too much
fullonoob said:bigbore said:fullonoob said:is it ok to use 4S?
4S is too much
couldnt i turn the setting down..
