Buy a Satiator charger, from Grin, it will do it all! But you can find battery tenders for under $10. I don't know where a BRANDED Battery Tender Jr. can be found for $15 maybe dssguy1 can point that out? But, "old" tech SLA batts are here for the foreseeable future.dssguy1 said:cwah said:i don't really want to buy an extra charger just for charging lead acid.. it's old technology and won't be used outside.....
So if I set voltage to 14V that should be fine?
I use a Battery Tender Jr, they cost ~$15 and have 6-8 different programs they automatically use to keep a lead acid battery properly charged.
fortisi876 said:Any chance on getting an update where we are on the list? Timeline?
The welds are pretty solid but most of my welds were relatively easy to pull off. A quick jerk with a pair of pliers. It is possible to distort the cell negative side casing. So far the cell bodies have not been ruined, at least not visually.Offroader said:Quick question, if I weld a pack with this welder and then decide I need to pull the tabs/welds off to make another battery configuration. How difficult is it to remove what I have welded to start over?
I basically need to know if I can change my battery configuration easily or should I expect this to be a permanent weld?
Thanks.
Thanks.
tomjasz said:Buy a Satiator charger, from Grin, it will do it all! But you can find battery tenders for under $10. I don't know where a BRANDED Battery Tender Jr. can be found for $15 maybe dssguy1 can point that out? But, "old" tech SLA batts are here for the foreseeable future.dssguy1 said:cwah said:i don't really want to buy an extra charger just for charging lead acid.. it's old technology and won't be used outside.....
riba2233 said:Here you go:
http://www.aliexpress.com/item/18650-battery-welding-fixture-18650-battery-fixed-clamp-18650-Battery-Fixture-Clamp-for-2-6-batteries/1907351540.html?spm=2114.01020208.3.1.EiIzVs&ws_ab_test=searchweb201556_2,searchweb201644_0_79_78_77_82_80_62,searchweb201560_5
fullonoob said:where do you have it connected right now? it make sense to have it on the +
shawname said:My welder is always live- the copper welding tips always have 12 volts.- Does the circuitry connect to the positive pole of the battery or the negative? Any ideas as to what I am doing wrong?
thanks,
Shawn
fechter said:riba2233 said:Here you go:
That looks handy. Bet I could make one out of a piece of wood.
