wesnewell said:That's the newer kit. The rim is not as wide as the older one, but you can get a Cyclops on it. That was the size of my front wheel I put one on. That said, if you can find a wider rim, the ride will be smoother, more stable, it will be easier to mount the tire and tube, and you won't have to worry about rim brake calipers rubbing the tire if you have them. Here's the rims I use. They are a lot stronger than standard narrow runs too.
http://www.weinmanntek.com/Products/FREESTYLE/DH39.htm
Alex DX32's have almost identical specs and would be a good choice too. And you can find these fairly easy, but more expensive.
http://www.amazon.com/Alex-DX32-26-36H-Black/dp/B001CJX3B6
I ordered a pair of these and stripped the rim off one to use with the motor.
http://www.amazon.com/Weinmann-DH-39-Alloy-Nutted-Black/dp/B000C15EBW/ref=sr_1_19
Chalo said:That rim looks adequate for the job. In the late '80s and early '90s we used tires that size on rims 19-20mm wide. It wasn't ideal, but it worked.
The optimum rim size for a CST Cyclops 2.4", Maxxis Hookworm 2.5", or Schwalbe Big Apple 2.35" (all the same size in the real world) is close to 40mm wide (or more specifically, about 32mm inside width). I have rims 32mm, 35mm, 38mm, and 45mm wide (outside) that all work great with tires in this size range.
The Stig said:Chalo said:The optimum rim size for a CST Cyclops 2.4", Maxxis Hookworm 2.5", or Schwalbe Big Apple 2.35" (all the same size in the real world) is close to 40mm wide (or more specifically, about 32mm inside width).
Think these 24x3.0 tires would work with a 32mm wide, 24", Alex Dm24?
(I'd probably be more flexible with the tire choice than the rim choice)
wesnewell said:I wouldn't use a 24mm rim on a 2.3" tire, much less a 3.0" tire. If you like Alex rims, then get the DX32 for tires over 2.0", up to ~2.7". Anything over that and I'd get an even wider rim. I rode thousands of miles with 2.4" tires on 24mm rims before switching to 32mm rims. And I'll never use another narrow rim on large tires. That 7mm difference doesn't sound like much, but it makes all the difference in the world.
wesnewell said:Shock absorption is better since there's more air volume. [with a wider rim]
They sell 2 different 48V 1000W kits. The newer one has disc brake mounts. The older one like you bought doesn't. You can add a disc brake flange later if needed.Martog said:Boy you guys weren't kidding about the cheap tube and need for rim tape!
Oh yeah - couple of points:
I ordered the 1K kit from Yescom's eBay seller and received the silver "Champion" wheel - and it did not come with the disk compatible hub. Not a big deal as my EVG doesn't have a rear disk tab anyway.
But it looks like the other sellers may be sending out the disk compatible version while Yescom is not. But who knows if that is always the case.
wesnewell said:If you think is narrower rim is better, just say so.
Chalo said:wesnewell said:If you think is narrower rim is better, just say so.
Wider rims keep the tire more stable laterally. Narrower rims give better ride quality at the same pressure. I've been putting the widest possible tires on all kinds of rims since the 1980s, and I've had a lot of chances to observe the results.
I prefer wide tires on wide rims, with low pressure. If for some reason I wanted to use high pressure in wide tires, I'd use a relatively narrow rim to yield the best ride.
babyhughie:
Make sure your rim strip is centered and not riding up on either side of the rim anywhere. Then mount your tire and inflate it to volleyball pressure; you'll need to be able to rock the tire back and forth by hand. Work your way around the wheel, massaging the tire into its bead seat. Then hold the wheel by the axle, and spin it while watching the tire at the rim edge. If the tire appears to pop up or sink down on either side, wiggle it around until it's even around the whole circumference. Then inflate to full sidewall pressure (65psi) and check again. If it's still even, let off the pressure to the desired level (start at 35psi and adjust from there to your taste).
Your tire will fit on your rim unless there is something wrong with the rim.
babyhughie said:Thanks for all the support fellas.. You guys are really motivating me to get this to work.. Between you guys, not wanting to wait another week for another tire/tube and money it'll cost I WILL get this to work tomorrow.. When I do I will post a picture
Chalo said:babyhughie said:Thanks for all the support fellas.. You guys are really motivating me to get this to work.. Between you guys, not wanting to wait another week for another tire/tube and money it'll cost I WILL get this to work tomorrow.. When I do I will post a picture
Deep rims like yours have spawned a new kind of tube with 48mm long valves. Get that kind of tube, even if it isn't quite fat enough. It should cost about the same as a normal tube with 32mm valve.
