teslanv
Are you running stock phase wires on the Yescomusa motor or have you upgraded those? And how about cooling?
teslanv said:Are you running stock phase wires on the Yescomusa motor or have you upgraded those? And how about cooling?
cool thanks. Is there a specific type of solder to use for maximum efficiency? or is regular rosin core solder ok?evolutiongts said:Greentime controller is great especially for $50, plenty of features most I don't even use. It has regen make sure when you order you specify the low voltage cutoff otherwise regen won't work. Shunt mod is easy just open up the controller the shunt is a upside down u. Just add solder to it and you will get more amps.
My greentime controller puts out 36 amps stock, by adding a ton of solder to the shunts I got it up to 48.99 amps (CA limited)
evolutiongts said:Greentime controller is great especially for $50.
wesnewell said:Don't use acid core. http://endless-sphere.com/forums/viewtopic.php?f=2&t=31643
Controller
http://www.aliexpress.com/item/Free-shipping-72V-1500W-45Amax-BLDC-motor-speed-controller-15FET-4410-s-Electric-Bicycle-Controller/499889986.html
Thanks bud, I just noticed that the seller gives a spare set of bare end Anderson's with the battery..evolutiongts said:I ended up rewiring the connectors on the controller to andersons
evolutiongts said:Currently running a CST cyclops 26x2.4 up front with thick tube and Schwalbe Marathon Plus 26x2.0 with tire liner and thick tube in the rear. The stock rim is very narrow, the largest tire I was able to fit on the stock rim is 26x2.1, I would personally swap the CST cyclops to the rear, because there is more weight in the rear.
I like having a narrower tire up front to have quicker steering. I actually have a schwalbe big apple coming in this week and will have that in the rear.
wesnewell said:The stock rim was 24mm inside, 32mm outside. I ran 2.4" Cyclops on it until changing the rim. Only problem I had was I had to add spacer the the rim brake pads to keep them from rubbing the wide tire. But the ride is much more stable on the wider rim.
babyhughie said:I haven't yet ordered the tires, If I can mount the cyclops on the stock rim without difficulty and it is a decent ride quality that is what I would like to do.
