stancecoke
- Joined
- Aug 2, 2017
- Messages
- 1,820
please use the DIAGNOSTICS mode or the BluOSEC app to see what the controller is doing. (controlstate, raw values of ADC Voltage reading.
regards
stancecoke
regards
stancecoke
Thanks for advice again, received Uart yesterday but unable to read any Data I think I might have blown uart by connecting 5v from controller. Originally connected via com 3 but now no longer shows in drop down. I've followed connection diagram connecting black yellow and green to corresponding controller display output. I then stupidly connected red uart cable to controller red pin and the Uart no longer works.stancecoke said:please use the DIAGNOSTICS mode or the BluOSEC app to see what the controller is doing. (controlstate, raw values of ADC Voltage reading.
regards
stancecoke
reset said:I then stupidly connected red uart cable to controller red pin.
Never connect VCC directly to the red wire of the display connector, this will destroy the module!
stancecoke said:Can you check if the advance angle is stable?
thanks,i have set motor special angle :237,the motor sound quietly.
throttle min-max:43---245
gear ratio :44.2
without pas limit speed:25km/h
(the newest fw)when the throttle is full ,the BLUOSEC app shows the speed 15.4km/h.
i measured the revolution is 183RPM. wheel size is 18' . so the actual speed 15.7km/h.
1:when the throttle is full, the speed should be 25km/h???
2:i rotated the motor not easily while the power 36v was turned on and no throttle.when the power 36v was turned off,i
rotated the motor smoothly.so how to make it run unhindered ?
regards
stancecoke
The tutorial says:
regards
stancecoke
The tutorial says:
reset said:Did you have any thoughts on the system not restarting when under 19v, do you know if anyone has tested this with a variable power supply.
haiyi911 said:(the newest fw)when the throttle is full ,the BLUOSEC app shows the speed 15.4km/h.
That's normal, you will not recognize it while cycling or pushing your bike. The control loop needs some time to contol the battery current to zerohaiyi911 said:2:i rotated the motor not easily while the power 36v was turned on and no throttle.when the power 36v was turned off,i
stancecoke said:reset said:Did you have any thoughts on the system not restarting when under 19v, do you know if anyone has tested this with a variable power supply.
What is the problem? Do you use display and the display is not starting? Or is the display working and the PWM doesn't start, in this case please check the voltage on the blue wire. Or do you use a jumper from red to blue and the PWM doesn't start?
What is the value of the big resistor on the left of the board?
regards
stancecoke
reset said:Yip it's the display no longer comes to life if it's switched off during use.
I don´t have such knowledge. If you get it done, please share the information. Thank you.stancecoke said:reset said:Yip it's the display no longer comes to life if it's switched off during use.
So it's a problem of the LCD, not of our firmware.
You can try to pimp your LCD, there seems to be the possibility to tune the shut off voltage, see here:
https://endless-sphere.com/forums/viewtopic.php?t=94070&start=25#p1382956
Perhaps you should ask casainho or nieles how to do the mod. I'm not familiar with these LCDs...
Should I expect the KT open source firmware will work with these controllers?
Valopallo said:Aye! <3 Finally, everything works, except I cannot reverse PAS direction neither I can't turn ON the offroad mode... Would it be cool to have offroad enabled from the BluOSEC app somehow? Is there?
If you found the right value for PAS threshold, the function PAS inverted will work properly.PAS threshold: Threshold for direction detection from the PAS signal. The value should be the arithmetic mean of the reciprocal of the duty cycle of the PAS-signal during forward and reverse rotation. The appropriate value can be determined by trial and error or by looking at the displayed values at turning the pedals forwards and backwards in "Diagnostics" mode, or look at the value of PAS fraction in the BluOSEC app. Set PAS threshold to a value somewhere in the middle between the value at pedaling forwards and the value at pedaling in reverse. The preset 1.7 was determined for a simple PAS with 8 magnets.
Thanks.Xnyle said:Should I expect the KT open source firmware will work with these controllers?
Second one yes, first one, I doubt it, don't see a STM8 on there.
Edit: Second one only limited support for the ZWS type, @see FAQ here:
https://github.com/stancecoke/BMSBattery_S_controllers_firmware/wiki
As I have understood the lcd will not be able to change settings in the controller.
You have the app instead. Will I be able to have both the bluetooth module and the LCD3 connected at the same time?
How about cruise control, is that still precent? Ither from LCD3 or hard wired on the controller?
And light switch, when I turn on the lights on the LCD3 I get a signal from the controller for the lights on the bike. Is that still there?
Yes, that works.j bjork said:Wait, change assist level. Does that work?
both features only need very little changes in the code.j bjork said:To loose cruise control and light control would be bad though.
