honya96
casainho said:At slow loop 10Hz, using PI controller, only motor phase current is being controlled for the value defined by the rider, using for instance, the throttle.honya96 said:My smaller "big" bike can take 50A battery regen current if overvoltage limited... just saying
VESC config looks good, would love to have same with kunteng and I hope the way you are implementing will do the job for this summer.
The max values limits are controlled every PWM cycle. I think is easy to understand my implementation, because it seems "quick and dirty". And as you can see, controlling battery overvoltage is done
Consider adding under voltage also if its not done yet. So we dont get cut, but reduced power. :wink:
I hope I can test soon, expect real next level compared to last I tested (atleast for my application)
