torqueboards
Minor legend
You can extend the mounts pretty far but you don't need it that far. It's somewhere in between 75mm to 95mm center distance.
randyc1 said:Do you think a slightlly harder ABEC 11 would be a good comprimize for better range?
torqueboards said:What are you using to charge your pack? LiPo charger?
As for the high speed issue and the brake issues. I haven't come across those issues. Please let me know if you find a fix for those issues or if you find out what's causing it. I am looking more into creating the VESC very soon.
dec said:whitepony - do you have any idea how many amps you're pulling from that battery pack at peak? and is a 'peak' a few seconds or, say, 20 seconds as you pull up a hill?
whitepony said:sanded the board down from 8 to 7ply maple for some minimal flex increase. at the same time I also flattened the middle section by removing parts of the 7th maple ply - roadside you cannot see anything of the w-concave anymore, so hopefully the new enclosure will look even slimmer and more integrated than before. finally I spent quite some time trying to get a decent finish ... went with a glossy carbon grey metallic look and Im really happy how it turned out! will also fit the elegant carbon+aluminum enclosure perfectly!![]()
randyc1 said:Can i ask how you painted the Underside ?, what kind of paint ?, did you use a Gun ?
smashapotamus said:Electrically, when you were welding the parallel cells together, did you weld nickel strap to both sides of the 4p cells or did you only do the inner sides? Is the parallel connection on the outer sides of each 4p cell completed through the same nickel strip that is also carrying the series current between cells? ... or are there 2 layers of nickel strips along the outer sides of your battery pack?
smashapotamus said:Well you've inspired me. Building a 12s4p pack of my own from LG he2's and aiming for a similar form factor to yours. Now I just have to figure out how to charge it.
whitepony said:smashapotamus said:Well you've inspired me. Building a 12s4p pack of my own from LG he2's and aiming for a similar form factor to yours. Now I just have to figure out how to charge it.
nice to hear! the cool thing about 10S is, that there are a million really cheap pedelec 36V chargers out there (they usually CC CV charge up to 41-42V): ebay
the evolve charger is exactly like that and, while it is not very fast, it does the job on 2 batteries for over a year now - and both show ZERO drift!
if it has to be 12S, okp is currently tinkering with his first 12S4P DIY battery (boards at that voltage with our regular 200ish KV, motors are just too fast imo - or you have to use weird gearing with small front pulleys and then you might run into belt slip issues. but thats just my opinion)! he wanted to split-charge the packs as 2x 6S, which you can often do with the cheap chargers via 2x balancer ports at the same time. possibly you can find similar simple notebook style chargers for 12S as well though!
delta_19 said:first right now your using a laptop jack for charging in parallel with your discharge leads, right?
delta_19 said:if so how do you balance your pack? I thought you removed the bms or just straight up didnt use one?
delta_19 said:also that button is it just a normal high volt/amp maintained push button to open and close the circuit to the esc's for turning the board on and off/charging?
