Hi All, just got my box O' wheel/motor and battery from the far away shores of China and I've got some questions I wonder you might be able to help with.
The harness came completly connected and everything seems to run "ok-ish" but,,,
-Of the three phase wires the yellow is connected to the green, the green to yellow and blue to blue. Is that correct? What would happen if I lined things up?
-When the motor begins to spin there is a clicking sound that disapears once the rpm picks up. This happens only going from low rpm (stop) to high.
-The display is SW900. I'd like to use only PAS with no throttle input (0) but setting #10 doesn't seem to accept any option the throttle is still active. Normal?
-If I want to change display would I have to change controller as well?
