Okay. Ended up going out in 85F weather instead up the 6 mile moderate hill climb.
Conditions:
- slight tailwind
- no downshifting to improve efficiency
- pedaling at mid effort
My power peak was north of 1600w. The motor can also sustain 28mph on top gear with me pedaling up about 1% grade. This is a pretty impressive feat considering i am 250lbs.
I measured a peak temp at the top of the hill of 70.5C and the unit rapidly started to cool down as soon as i unlocked my phone to take this picture.
The mid drive provided an admirable performance and even achieved a top speed of 33mph on flat ground. The pedaling cadence still isn't too high.
While climbing, i could see wattages from 1050w to 1300w. About 1.2kw continuous average.
I think i am right on the edge of pushing it too far at this point. This would have melted offroad or in truly hilly conditions under moderate operator neglect + high ambient heat.
I could feel the power just beginning to falter at the end of the ride, so that stator is 80C or higher inside.
I think the required modifications needed to keep this tune are:
- add heatsink(s) to the stator side for hopefully 15% better heat shedding ( i have 12.5mm of height )
- add NTC 10k sensor and wire to the VESC + program in some mild thermal rollback
Otherwise, the correct thing to do would be to shave off 100 watts, or downgear by 2T on the bike side chainring.
Regardless of this, the efficiency was exceptional. I came home with a much higher charge on the way home than expected.
If I could find a watercooling block with the correct inlet/outlet orientation and height ( shouldn't be impossible), i think i could add a few more hundred watts, since the case is thermally linked to the stator so well.
I am seeing if i can get another internal clutch so that i can test the mechanical limits, since i've got a good idea what the thermal limits are now.
