I am currently riding a 2000W hub motor bike I built last year. It is a poor choice for mountain biking, as it groans like a professional wrestler at low RPM on the trail. Probably makes more noise than the mid-drive will. The only ebike noise that bothers me is the one I make just before crashing, or when the gears on my hub motor start stripping. On the road, I am not near other cyclists/pedestrians long enough for them to get annoyed (I top out around 45kph). On the trail, I get annoyed (not really) when everyone I meet wants to stop me and talk about my bike. My next build will be a low-speed trail monster, and I will be out in the back country most of the time with it. Hopefully, the wildlife won't get too annoyed with me.All that matters is two aspects of real world testing:
1. Does the sound annoy you (the operator)?
2. Does the sound annoy/scare/freak out other cyclists or pedestrians?
jdevo2004 said:[youtube]eUMEhpAw7sk[/youtube]
--freeride-- said:If you don't want your chain to fall of the front sprocket there is a good solution.
Get a damped derailleur Shimano shadow PLUS
or Sram Typ 2
They both have a damper and keep the chain in place.
Problem is, they are only available for 10 speed. But there is a solution too. With an old 8 or 9 speed Sram shifter, you can use 10 speed Shimano derailleurs.
The Shifter defines what your derailleur runs at. So you get a 8 or 9 speed like the shifter is.
That is the only combination that runs. The rest is not compatible!
ebike11 said:Sorry to go off topic guys.
Im using 25h chain and sprockets on the primary side.
To tighten everyything up with LR sheets..do I only need lower sheets or both upper
and lower sheets? Thanks
emaayan said:shouldn't something like this stop it from happening it? http://www.chainreactioncycles.com/il/en/e-thirteen-xcx-st-chain-guide/rp-prod61087
most chain guides i saw fit on the bb, and i'm assuming there's no room for such thing.
i thought about getting something like this, but since i'm using an alfine, and sliding dropouts. and adjust my chain to always be same and tension and line.
The bb is part of the kit a freewheel 145 mm longjimnasium said:emaayan said:shouldn't something like this stop it from happening it? http://www.chainreactioncycles.com/il/en/e-thirteen-xcx-st-chain-guide/rp-prod61087
I kept my front derailleur, and 2 out of the original 3 chain rings (42/34). My problem is that my front shifter has 3 shifting positions, so if I overshift, then my chain falls off on the inside. I adjusted my "L" screw on the derailleur to minimize this, but it's not foolproof.
I noticed that the bottom bracket in the video is very different from mine. It's much longer so that the adjusting screws are really far away from the chainring. Mine are actually right inside, meaning that the adjusting bolts catch on the chain when it falls off on the inside. Ouch!
do you think it would ok to try and use a BMC controller for the motor? the reason i'm asking, is that the controller (i got from ilia) is the only one that managed to survive this long with my bmc motor, only now it's undergoing repairs for being shorted out for some mystery reason, and the tech guy says it's built to withstand enormous loads, it's cools off so fast, he can barely soldier transistors. my previous infineon controllers i got from em3ev, didn't seem to last long, even the current one, i suspect may have hall sensing issue (sudden small stops)
