r3volved
It really sounds like there are a lo of users out there who have a misunderstanding that the upper adjustment (jackshaft) is to tension the belt and the chain...the upper adjuster is for BELT tension only!
The lower adjusters are for adjusting the chain.
If you're only using the upper adjustment and trying to tighten both chain and belt with it, then nothing will ever be squared and there will always be alignment problems...
