LightningRods
The problem is twist in the upper bracket. We can solve that by making the bracket more rigid or by adding a torque brace.
jimnasium said:
The lower sheet and upper sheet form 2 sides of a triangle. It would make sense to close the triangle with a bar or bracket along the top. It would have to be adjustable of course, given that the other 2 sides are adjustable.
Is he using 50v pack? in fact is ANYONE using a 50 v pack and reaching such speeds with this kit? cause im always thinking this uber volt kit and anyone reaching 60 kph is probably using monster packs.LightningRods said:This comment just came in from a customer in Croatia. This is what I like to hear.![]()
"You are making a good work, I am completely satisfied with my motor, going more than 55km/h on flat (just a short test, it is too dangerous on bike, I ussualy go 40), 1100km without issues, belt is like new, once adjusted I do not touch it anymore
Thanks"
skyungjae said:I've gotten very close to 55kph (hit 33mph) with the stock GNG 1.0 at 48V... I was pedaling super hard though. :lol:
Wouldn't it be wonderful if there could be a simple common procedure a measurement could be taken off the road wheel to report a useable power index? I love all the "how fast..." posts but so many are plain useless when a reported number comes from so many uncontrolled variables. With such a standard in place at least people can run tests using as many common variables such as no pedaling, gearing, GPS reporting on road with clear view of sky, 0% incline, smooth tarmac road surface, no measurable wind, test both directions on test section, etc. Then maybe a section to report less controlled variables such as rider weight, bike weight, wheel type, size, pressure, rider position (prone, upright), etc.Don't expect the same results from your 45 lb fat bike with 3" tires and a 250 lb rider on board.
emaayan said:offering what? placing the heat sensor?
btw is this an In-runner?
LightningRods said:emaayan said:offering what? placing the heat sensor?
Upgrading the gauge of the phase wires. If you don't want that I'll be thrilled to give you another motor with the standard phase wires and the temp sensor. There was a lot of noise about heavier gauge phase wires and various connectors a few weeks back. I don't dispute the value of heavier gauge phase wires, I just can't do that in a production environment.
Yes it's an in-runner. The one with the heat producing copper windings bonded to the motor case for better heat dissipation.
emaayan said:or i could be completely wrong, and find myself chugging at 28 kph.
LightningRods said:emaayan said:or i could be completely wrong, and find myself chugging at 28 kph.
I'm going to keep saying it in hopes that it may sink in. You are gearing your bike much too high. First gear should be very low, in fact low enough that you may not use it very often for starting out on flat ground. If you have an 11 speed your top speed should be attainable in 9th, with 10th and 11th as 'overdrive' gears for quiet cruising at speed with low current draw.
If you have geared your bike so high that top speed is reached in first gear and all of the higher gears are so high that the motor can't pull them, what is the point of having multiple gears? You have first, second, and then unusable 1,2,3,4,5,6,7,8 and 9.
An 11 speed is too many gears for an electric bike but at least the broad spread between 1st and 11th should be good.
emaayan said:i always assumed that low wattage of the motors (BMC was rated 600 watts, and MAC was rated 1000 and actually was recommended to be used with 36v ), was what prevented them from being usable at higher gears , so now i'm hoping of even higher wattage on the GNG motor along with low rpm, would allow me to actually start at gear 4, 5. and quickly move to gear 6, 7 after picking up speed.
windtrader said:So how fast???????? LOL
Anyway love the progress LR! Congrats!
LightningRods said:emaayan said:i always assumed that low wattage of the motors (BMC was rated 600 watts, and MAC was rated 1000 and actually was recommended to be used with 36v ), was what prevented them from being usable at higher gears , so now i'm hoping of even higher wattage on the GNG motor along with low rpm, would allow me to actually start at gear 4, 5. and quickly move to gear 6, 7 after picking up speed.
There is some truth to that. If you have enough power you can pull much higher gearing. But based on the top speeds available in each of your gears (I calculated all of this for you previously if you remember) it's well beyond the power capacity of even my more powerful motor.
You are creating a high amp/low volt situation with your high gearing. This is probably much of the reason that you have been cooking motors. Lugging an electric motor at low rpm/high current draw will make it hot. My motor will cope with this better than the BMC or MAC did but there's still no good reason to do it.
Do yourself a favor and set my kit up with the standard 12T/80T secondary drive and see how it does. I would guess that even at 50V/40 amps it will still not pull full rpm in 11th because as I remember you're geared for nearly 90 km/hr in that gear. At 48V/40 amp my small block should be good for 60 km/hr. If you want to go 90 you need a big block.
