Hi Mike !... and Hi to all the builders here
I have put my money down on one of Mikes kits - to start my new build on my 2007 Kona Stinky Primo.
I am a third year engineering student - and have decided to make this build - my final year graduation project.
as such...i must document and calculate everything - in order to justify and defend my project. (like a Thesis).
So my appologies ahead of time - if i ask too many detailed technical questions - as i not only need the bike to work! but also to be able to prove by numbers and calculations - how it works! :wink:
I have been on this site (and others)for over a two months learning and gathering info - so as to ask as few stupid questions as possible...but still..have many.
So for the sake of others after me ( and since im doing it for my project anyway!) i will post as many of the build details here as possible..
So for starters - my Goals:
To make a downhill Electric bike - capable of taking me on my daily commute - of 30Km (roundtrip) on one charge! All off road! including about 300m acumulative climb on the way.(as driving on the highways is too scary!)
To make the 15Km (one way) to work..in less than 40Min. (so i dont have to get up at the crack of dawn!) as i have to be at work at 7:15! and so i can get home quickly.. this means a 40 kph average speed (as roughly half the trip is uphill and the rest is flat) then half the time i will be going half the speed(15kph) uphill.and half the time - one and a half times the speed(65kph) on the flat - all of this on dirt roads! or trails. with big fat, high friction, power eating tires!
For the bike to still be a viable agile downhill bike! - with the added ability to climb back up to the top of the Track! (without having to pedal too much - or get shutteled back to the top) - and make as many Downhill runs as possible on one charge!
For the Batteries to be compact enough - to fit in a backpack - or on the bike.
Now for the bike:
Its a Top of the line Model of the 2007 Stinky - with The floating brake system - thats been heavily upgraded !
Front Fork - 2008 Marzzochi 888 World cup Rear shock - Marzzochi Rocco.
Dangerboy 780mm riser bar handlebars with ODI grips.
Brakes - Hope Tech M4 four piston calipers on Hope floating disc rotors 203mm front/180mm rear .
Shimano deore drivetrain - with SRAM X-7 shifters and derailer.
Maxxis 2.5 rear and 2.7 inch front downhill tires on QUAD rims.
