classicalgas
- Joined
- May 14, 2016
- Messages
- 486
yeah. my vampire loads are minimal, the one I drive most often is a 2000. Before I put a pv trickle charger on it, I could go a week or two without driving it before I noticed starting issues ( though not always a need for the jump box, sometimes it was just slow, or almost wouldn't start....two months, and it might not even turn over. That seemed to be unchanged when the AGM died and I bought the lithium (only about $75 difference in price ) So I decided the pv trickle charger might make the more expensive battery last longer, and get away with something smaller than recommended. So far, so good.Wow, only 1.8w, and that worked for you..
How old is your miata? i'm imagining a 1990's-2000's model that didn't have a ton of electronics sapping at the battery all the time.
I see that i can get up to a 20w dashboard solar charger. Possibly this could make a 30ah battery work.
The Shorei weighs just an ounce or two over five pounds , including the battery adapters (from motorcycle to automotive connections ) The special Shorai battery minder wasn't cheap, though you don't need that with the PV trickle.
Some aero tweaks and 150 lbs out of the car bumped my highway mileage on the miata (notoriously geared low, 5th isn't even 1:1) from 26 mpg to 31 ( if I keep it under 75mph)
