themotorman
- Joined
- Dec 9, 2009
- Messages
- 20
I bought one to look at and it is 18 mm dia. x 65 mm long , It does charge to 4.2 volts and delivers about 800 mA-Hrs after two cycles, it also will dump nearly 25 amps into a short. I did accidentally let it discharge to zero, and with much surprise, it recharged OK! This is a long way from the 2800 mAHrs as marked and advertised l!! I did find a reference to someone who has tested all the li-ion of this size he could find including this one but I cannot locate the link.. sorry. Some of the of the cells in the same size did deliver nearly 3000Ma-Hrs and according to the tests, and are LiMnPO4. They are listed on line by battery websites and cost as much as $12/cell. If in fact you can let them go to zero without having a dead cell ( like LiFePO4 's ) then that would be a real advantage as it makes them usable in places where a BMS is impractical like flashlights. I will try and look through my old history and if i find the reports on the testing I'll post it here.DAND214 said:No Joke, they are listed. the question is are they what they say they are.
3 amps out of these cells
http://cgi.ebay.com/24-x-18650-GTL-Li-ion-3000mAh-Rechargeable-Battery-3-7v-/110538726410?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19bc9f1c0a at what c rate? Sure wish there was more data. REAL DATA!
Dan
