Added features:
* RF Digital isolation (instead of opto)
* Isolated DC-DC draws power from USB, does not center tap pack
* Opto-outs for LVC, HVC, Charger Shutdown, AUX
* 1.2A programmable balance currents
* LED shunt indicators
* 3 fans
* Extruded aluminum housing
* 4 x IRFB 4115 150V fets for throttling up to 50A charge current
* Boards stack via header connections then slide into box
* Fans mounted on lid - slides on and off
* isolated grounds: USB ground, Battery Ground, Charger Ground (switched in via 4115)
Features:
* Programmable charge throttling
* Programmable set points for everything (LVC, HVC, shunting, etc)
* Programmable behavior
* Ultra low battery draw
* Cool housing (housing stays only 10C over ambient at 125W balance power)
* Full GUI interface -> Datalogging, settings, etc.
* WDT enabled -> cuts balance and charge in case of fault
V3.0 will be modular in 12S chunks aimed more toward the ebike crowd but still able to service the full size EV market.
-methods
