ricksta said:
Hello Method,
Good work on your BMS. I like your thinking with the 20amp shunt current. I support you all the way for that idea.
I see you have 5 x 20ohms in parallel shunt resistors. at 1.25amp each resistor is only getting 250mA of current. or dissipating 1watt of power. why does it get so hot at 150degree with 2 big fans blowing on it? if they are rated at 1watt shouldn't they stay at like 70degrees?
They are 1 Watt resistors and I designed it such that they burn under 1 watt each. With the fans blowing the resistors stay under 60C (surface temp) at 25C ambient and the case never gets over 35C.
If you read the data sheet you might think that you can actually run a 1W resistor at 1W but that is not the case - nor is it the case with any part (mosfets etc). It is assumed that you have a certain amount of heat sinking through the pad contacts on the board. There is enough data in most datasheets to calculate just how much pad you need.... but I can assure you that when a component is rated they are very generous to themselves.
This power rating is also assuming you have a 25C ambient. What happens when you put 190 1W resistors in a small box and run them at 1W? Well... that 190W is going to heat the box up FAST. Now Ambient is no longer 25C, now it is 100C, then 150C, then.... You see we are adding energy to the box from the pack right? Without a VERY large heatsink - where is that energy to go?
Take for instance a 180A IRFB 4110 mosfet.
How long do you think you can run 180A through there before it overheats? (about 1 second tops)
How about even 20A?
So - the deal is that parts are very misleading in how they are rated. It is important to know what the ambient temperature is, how fast you are warming up that ambient, what the C/W is of the part, and a bunch of other stuff.
So - to answer your question - those resistors hit >150C in about 5 seconds without the fans.
Believe it or not - I can show you a video if you like.
The original design called for two much smaller fans that fit inside - but even with them blowing full blast the surface temps rose to over 120C at ambient. Now imagine how hot ambient can get if you are stuffed inside of a motorcycle gas tank running all those resistors for 5 hours.
I think that if you analyze many BMS designs you will find that they are running their axial resistors WAY hotter than they are rated for. This heat is very damaging - bot to the resistor and all the parts around it. It is very important to keep a circuit running at a cool consistent temperature if you want consistent results. For instance, the LTC is only rated to meet spec at up to 85C. If I heat-sunk those resistors down thru the board or into the case the LTC would quickly heat up to the point of providing less accurate readings. As it stands - I have a temperature probe on the LTC and it is no warmer with the shunts on that it is without. This thanks to the fans.
-methods
