BYqSXt8Z
So I'm trying to test some lifepo4 batteries and I've come across a very strange behaviour. I'm hoping someone here may have an explanation for the phenomenon in question.
When I discharge batteries at 0.5c, I get near nominal capacity, and the measured charge Wh is generally pretty close to the discharged Wh. Now there are are thermal losses and I'm suing 2 different devices, so I can forgive the 5% or so difference I see.
Where it becomes puzzling is at 0.025c. Discharge capacity becomes less than half of nominal, but charging on the same device charges up the nominal amount.... What could be causing this? Is it normal?
At first I assumed a faulty cell with a large power loss over time and so a longer test would be more affected, but it seems to be an effect I can repeat. Without a good ir tester I also can't do much to confirm that aspect... Any insight would be helpful.
Thanks!
Sent from my CLT-L04 using Tapatalk
Thanks!
